Web Installer Fails on 64 bit Debian 7.x
After executing the web installer I get:
Verifying archive integrity... All good.
Uncompressing Xilinx Installer........  (...)
ERROR: This installation is not supported on 32 bit platforms.
This is on the amd64 version of Debian 7 (fully updated).
Hi @gdstew
Debian is unsupported for Vivado.
But some users had it worked. We dont support officially though.
https://0xstubs.org/setting-up-xilinx-development-tools-on-debian/
Thanks,Vijay
Hi @gdstew
Check if this thread helps: https://forums.xilinx.com/t5/Installation-and-Licensing/I-get-quot-ERROR-This-installation-is-not-supported-on-32-bit/td-p/597759
Vinay
Any particular reason(s) Debian is not supported ?
Also since it does not appear anywhere on the Downloads page (a logical
place for it to be), it would be useful to know which Linux is supported in
case the Debian install kludge or Vivado does not work using the latest web
installer.
Yes that is more helpful and answers the second question on my first reply as well. Thanks
Hi @gdstew
Here is the supported linux OS list
Linux Support
• Red Hat Enterprise Workstation 7.0 (64-bit)
• Red Hat Enterprise Workstation 6.4-6.6 (64-bit)
• SUSE Linux Enterprise 12.0 (64-bit)
• Cent OS 7.0 (64-bit)
• Ubuntu Linux 14.04 LTS (64-bit)
Thanks,Vijay
