WebPACK and ILA?
I'm using a WebPACK license with my Zedboard. If I include an ILA IP in my design I get:
ERROR: [Chipscope 16-111] License check failed for Vivado Analyzer feature - aborting debug core implementation...
Does this mean that the ILA IP can not be used with WebPACK?
Re: WebPACK and ILA?
Yes,Webpack License will not contain Vivado Logic Analyzer feature.
See below snapshot.This feature is avaible with Design Edition, System Edition licenses which you need purchase.
You can also use 30-days evaluation license (free license which will be valid for only 30 days) to use Vivado Logic Analyzer.
HI
Webpack license doesn't include license for debug cores.
If you want to use debug cores in your design,use 30 day evaluation license or buy full license.
Satish
You need to have evaluation or purchased license with you to use ILA.
Anusheel
Helpful answer -> Give Kudos
This should be clearly stated on the low end development kits marketing material as they are pretty useless without it, especially in the area of the Zynq where you can't simulate the full system. I would expect that Xilinx would like to educate designers on how to use Vivado Debug.
Altera include SignalTap II in their Quartus II Web edition as long as talkback is enabled.
