Visitor wvfishfearme
WebPack license NOGO
Freshliy installed v 12.1.     Am on WinXP SP3.
On startup, I get a license warning, select the fetch WebPack license, and the manager takes me to the reg. website. All seems well with the notification:
"Thank you for registering your ISE Design Suite product. The appropriate FLEXnet license key has been installed and the software is now ready for use."
Sorry, but the key is NOT found by the tool. Where might it be if not in the c: Xilinx directory?
H e l p, p l e a s e !
found one but just by guessing
hackerooooo
several .lic files. Looks like ISE is happy with the one in:
C:\Xilinx\12.1\ISE_DS\ISE\coregen\core_licenses
Did I miss some documentation?
Visitor kyle1352000
Re: found one but just by guessing
So, you just pointed Xilinx to one the license file located in that folder and everything is good now? Wierd... I was having the same issue. I am glad to see you figured it out. Thanks!
Kyle
Hi W,
Those license files are for coregen IP. The ISE license should be in the C:\.Xilinx folder.
I had an issue getting a non-networked installation running last week and it was resolved here.
Bruce
There is currently a bug in the WebSite that should be fixed within the next couple of days.  Going from XLCM to get a WebPack license currently takes you to the wrong page.  You should manually generate a WebPack license by going to download.xilinx.com -> 12.1 -> Enablement (bottom right hand side).  Log in and generate a WebPack license.  After doing so, store the license to your %HOMEDRIVE%/.Xilinx of $HOME/.Xilinx on Linux.
