What Linux OS versions will Vivado 2020.1 support?
Vivado 2019.2 supports CentOS 7.4, 7.5 and 7.6 (64).
Will next release support CentOS 7.7?
Tags (3)
Re: What Linux OS versions will Vivado 2020.1 support?
Hello christer.ostling@zarlink.com ,
Cent OS 7.7 is scheduled to be supported from 2020.1 release.This is subject to change, as this is under testing process at the moment. So, unless there are any major issues with this particular version of Cent OS, this is on the OS support roadmap to be supported with the new 2020.1 release.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hope this helps.
Kind Regards,
Anatoli Curran,
Thanks for the info.
I hope that Cent OS 7.7 will be supported by Vivado 2020.1 so we can avoid installing Cent OS 7.6.
Hi christer.ostling@zarlink.com ,
Based on the info I have, it is scheduled for 2020.1.
Have a nice day.
Kind Regards,
Anatoli Curran,
