Where is Vivado after installation?
After Installing Vivado Design Suite(2017.4) on Win10, there is no shortcut  to start xilinx vivado or license manager in the GUI . (It installed it under C:/XilinX). Which file to run after the install ?  Where is the shortcut that installer promised to create?
Soumya
Re: Where is Vivado after installation?
Hi @soumya.91singh,
You can invoke Vivado by running the vivado.bat file present under the C:\Xilinx\Vivado\2017.4\bin .
To add Vivado shortcut to Desktop or Start menu, please run  NetworkShortcutSetup.bat present under C:\Xilinx\.xinstall\Vivado_2017.4\bin as suggested in AR#56551
Thanks & Regards,
A.Shameer
Hi @soumya.91singh,
Thanks & Regards,
A.Shameer
Running the networkShortcutSetup.bar gives me the error: "Unable To Load Installation Data", although it seems I can run the vivado.bat file just fine.
Vivado 2019.1, Windows 10
