lumarray
Where to download ISE webpack for windows 7
1) Is the ISE webpack still available for download? The existing link points to ISE Design Suite.
2) If ISE webpack is no longer available for download, can I get a working license for ISE Design Suite free of charge?
feng
hemangd
Hi @lumarray,
ISE webpack supported devices:
For other devices you need to use full ISE design suite. To get the license of it, contact your FAE.
hemangd
rshekhaw
Hi @lumarray,
1.) For downloading ISE, please go to the below link:
https://www.xilinx.com/products/design-tools/ise-design-suite/ise-webpack.html
2.) For ISE license, it is now included in Vivado license.
Raj.
lumarray
Hi Raj,
Thanks for the reply. The page you referred to has a download link that directs to ISE Design Suite, not ISE webpack. We want to use ISE webpack because it is free. We have a very small project, and it doesn't justify the cost of the Vivado license. Anyway around this?
feng
hemangd
Hi @lumarray,
@rshekhaw has correctly provided the link to download ISE.
ISE webpack is free. You can download ISE 14.7 and use webpack to tagert XC9500 with windows7.
Check this thread, it will help you out on your confusion - https://forums.xilinx.com/t5/Installation-and-Licensing/Downloading-ISE-WebPACK-Design-Software/td-p/663260
You have to download entire package anmd install it on your machine. Once installed have webpack enabled on your ISE which is free of charge. Webpack supports very limited devices with limited features but this would work in your case. XC9500 comes under webpack supported devices so no need to purchase the license to target XC9500.
hemangd
lumarray
OK, I think I figured out the installation part. Can I still get free licenses for a particular FPGA part?
lumarray
I was able to get the webpack installed. How can I get licenses for the following targets: XC6SLX150 and XC7A100T?
feng
drjohnsmith
Have you tried ? I seem to remember that now, all parts ISE can work with are licences in the web pack,
Just a note, Ensure you have the correct ISE download, one is for windows 10, but only supports spartan ( I think 6 ) , the other does not work properly on windows 10, and needs windows 7 / linux.
lumarray
I did download the correct version of ISE for Windows 7/XP (Xilinx_ISE_DS_Win_14.7_1015_1.tar,) and chose ISE Webpack when ran the installer. After that, I obtained a node locked license through my Xilinx account. I only chose ISE WebPACK License under Product and nothing else.
When I tried to load my old project, it said "The Device is currently set to "xc6slx150", which is not valid in this installation..."
Do I need a device locked license, and how would I do that?
feng
hemangd
Hi @lumarray,
hemangd
