Visitor etb513
Windows 10
Hi all,
I am fully aware that Windows 10 is NOT a supported operating system for any versions of Vivado available at this time (2015.2 being the latest version available at the time of writing).
However, I am curious as to whether or not anyone has had any luck in getting Vivado to install and function completely on a Windows 10 machine, and if any specific steps were necessary to achieve this. I'd like to hold off from upgrading any time soon if it's not possible to use Vivado with Windows 10 yet.
Unofficial compatibility aside, is there any ETA for official Windows 10 support? Version 2016.1 perhaps?
Ethan
Visitor etb513
Re: Windows 10
My apologies, I intended to post this under the Installation and Licensing forum. If a mod would be so kind as to move this to the correct forum, that'd be great - sorry for any inconvenience!
Re: Windows 10
Hi @etb513
Windows 10 was released a couple of days before.
It takes some time for Xilinx to support this brand new OS.
Vinay
Visitor etb513
Re: Windows 10
Of course! I wouldn't expect official support until 2016 or later.
I'm more curious to see if anyone has had any success getting the tools to work with a little tweaking, as was possible with Vivado on Windows 8 before it was official supported. Pre-release Windows 10 builds have been around for some months now.
Visitor hamster
Re: Windows 10
Argh.... upgraded tonight...
[Common 17-345] A valid license was not found for feature 'Implementation' and/or device 'xc7a200t'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Have to start using a Linux VM :-(
Re: Windows 10
@hamster,
Do you mean you were not getting this License error before upgrading to Windows 10?
--Syed
Re: Windows 10
@hamster,
Also share the Vivado license file and xinfo report. To generate xinfo file, Run the below command from Vivado TCL shell and share the xinfo.txt log file.
report_environment –file <directory>/xinfo.txt
--Syed
Visitor xuroot
Re: Windows 10
I installed vivado 2015.2 in win8.1x64. and today, I upgrade to win10.
Just use license manager to refresh several times, and now, I could syn, impl, and generate bit file.
Visitor etb513
Re: Windows 10
Good to know, thanks! Does anyone know if you can do a clean Vivado install directly on Win10 or is it necessary to install on a previous version and then upgrade?
Newbie realdigital
Re: Windows 10
Not sure why, but the installer seems to stuck at "generating installed device list".
Suggestions? :)
Visitor xuroot
Re: Windows 10
I reinstalled a new win 10, and vivado. Till now, everything is working fine from my side.
Newbie tunaip
Re: Windows 10
Hi there xuroot,
I recently upgraded to W10 and installed Vivado. I am getting the license problem when I try to synth. Would you mind
explaining the spets you went throught in order to get it done?
Thank you very much.
Observer reichardt
Re: Windows 10
Hi folks,
does anybody already have experience with a new Vivado 2015.3 installation on a freshly installed WIndows-10?
Is the last ISE14.7 version compatible with WIndows-10? Any troubleshooting hints?
Thanks in advance
Juergen
Re: Windows 10
@reichardt
Win10 is an unsupported OS with ISE 14.7. It is always recommended to use the supported OS to avoid any unkown behavior.
Check page number 7 in the below release notes of ISE 14.7:
http://china.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Did you install ISE 14.7 in Win10? Are you facing any issue?
--Syed
Observer reichardt
Re: Windows 10
Sydez,
thanks for the info that the Windows 10 is not a supported plattform for the latest ISE 14.7
I don't have any experience with Xilinx tools on WIndows 10 yet, but I will soon have to install Vivado 2015.3 and ISE 14.7 on a new WIndows based computer and wish to know which OS to take.
In fact I think that it does not make sense to use the old Windows 7 and I don't want to use Windows 8.
I will also have to use both plattforms on the same computer because we are using FPGAs ranging from SPARTAN-3 to Kintex/Zynq.
So again my questions:
- How is the chance to run ISE14.7 on WIndows 10 successfully?
- Is Windows 10 already a supported platform for Vivado 2015.3? If not: Which Windows-OS is recommended.
with kind regards
Juergen
Re: Windows 10
@reichardt
Many of our customer have succesfully installed ISE 14.7 on Win10. But again since it is not tested by Xilinx it is not recommended .
For this you need to check the release notes user guide of Vivado 2015.3. Check page number 14 in below link to know the list:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug973-vivado-release-notes-install-license.pdf
--Syed
Observer reichardt
Re: Windows 10
hi syedz,
...so I conclude that Xilinx still recommends to use the old Windows 7 OS for both ISE and Vivado.....:-(
Do you have any experiences from other customers running Vivado on Win 10?
Do you know about Xilinx plans to port Vivado to Win 10?
Juergen
Re: Windows 10
@reichardt,
We do have plans to support Vivado with Win10 and developement is currently working on it.
But it will not be supported with ISE as ISE is now obsolete.
--Syed
Participant cesys
Re: Windows 10
If ISE is obsolete and Vivado does not support Spartan-6, does this mean Spartan-6 devices are also obsolete?
Re: Windows 10
Well, Xilinx?  Yes or no?
Re: Windows 10
Very interesting topic. What about Virtex5 + Virtex6?
Yesterday, Microsoft announced that future Intel CPUs (including the recently released Skylake generation) will have limited Support for Windows 7 and users should move to Win10.
What will Xilinx do?
Visitor kenwells85
Re: Windows 10
Pinging this conversation to see if there has been any progress on Windows 10 support with Vivado.  My company's IT department wants me to be the first FPGA engineering guinnea pig to switch to Win10 and I'm concerned that I'll waste a lot of time and it still won't work in the end.
Does Xilinx have a target date and a target version of Vivado that will support Windows 10?
Newbie k.jaulin
Re: Windows 10
Hi !
I installed vivado 2015.4 on Windows 10 and I can't use my Platform Cable USB II because windows don't recognize usb serial port com. With the same material but with Windows 7 it works.
I installed driver separetly from xilinx website and it doesn't work.
I can just see "Xilinx USB Cable" in Peripheral manager when I plug the device.
Somebody can help me please ?
Kévin.
Newbie mjb1972
Re: Windows 10
Is there a patch for Windows 10 and Vivado yet? I like 10, so I won't be downgrading. It would be nice to work from home on a modern computer. Please inform if there is support or when there is a projection for support. I've found nothing as of yet.
Visitor cube1
Re: Windows 10
I stumbled on this post while researching an upcoming Windows 7 to Windows 10 upgrade.
I find it pretty disappointing that Xilinx has taken this stance, and I think it is against Xilinx' best interests.  Consider these facts:
1.  Microsoft is now only providing security updates to Windows 7, and is thus essentially forcing users to upgrade to Windows 10, and to do it SOON - by the end of July 2016.
2.  Many of us have been working with devices that Vivado simply does not support.  It isn't an option.  Whether it be a case of a legacy device deployed by a smaller coroporation that does not have the resources to keep and extra development seat around, a university student, a hobbyist or a youngster just getting started, legacy devices have to exist in millions of devices, and give newcomers an affordable entry point into hardware development for your devices.
3.  You'd rather maybe I migrate to Intel/Altera?  I can tell you I am certainly look at that option right now.  If I have to upgrade to a new device, new development board AND new tools, there is no reason not to open up my investigation.
4.  The changes to get ISE running fully in 32 and 64 bit environments would be very modest, as one can tell from the workarounds.  But workarounds sometimes leave people with a *very* uncomfortable feeling about the future.
So why continue to anger and disappoint people when fixing it would be relatively easy?
