Visitor jhazt
Wrong hostid on SERVER line for license file
Greetings,
We've been serving up a floating license for quite some time now and the original administrator has left the company since. No one notices when everything runs smoothly, but unfortunately we've now had the network card go bad and we are scratching our heads as to how to rehost the license with a new hostid.
How can we get it to accept the new hostid (new network card) ?
Server log below:
16:28:17 (lmgrd) FLEXnet Licensing (v11.6.0.0 build 60117 amd64_re3) started on dalek (linux) (8/19/2013)
16:28:17 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
16:28:17 (lmgrd) US Patents 5,390,297 and 5,671,412.
16:28:17 (lmgrd) World Wide Web:  http://www.acresso.com
16:28:17 (lmgrd) License file(s): /etc/flexlm//DalekIseFloat.lic /etc/flexlm//XilinxKen1.lic /etc/flexlm//XilinxKen2.lic
16:28:17 (lmgrd) lmgrd tcp-port 2100
16:28:17 (lmgrd) Starting vendor daemons ...
16:28:17 (xilinxd) FLEXnet Licensing version v11.6.0.0 build 60117 amd64_re3
16:28:17 (xilinxd) Server started on dalek for:
16:28:17 (xilinxd) Embedded_Edition (consisting of:             ChipscopePro
16:28:17 (xilinxd) ChipscopePro_SIOTK sdk               xps
16:28:17 (xilinxd) PlanAhead    ISE             ISIM)
16:28:17 (xilinxd) Wrong hostid on SERVER line for license file:
16:28:17 (xilinxd)      /etc/flexlm//XilinxKen1.lic
16:28:17 (xilinxd) SERVER line says 000acd1896b2, hostid is 6805ca18b7d2
16:28:17 (xilinxd) Invalid hostid on SERVER line
16:28:17 (xilinxd) Disabling 1 license from feature ChipScopePro_SIOTK(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature ChipscopePro(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature Embedded_Edition(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature ISE(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature ISIM(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature PlanAhead(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature SDK(75BF28C79D8F)
16:28:17 (xilinxd) Disabling 1 license from feature XPS(75BF28C79D8F)
16:28:17 (xilinxd)      /etc/flexlm//XilinxKen2.lic
16:28:17 (xilinxd) Disabling 1 license from feature ChipScopePro_SIOTK(D403299BA828)
16:28:17 (xilinxd) Disabling 1 license from feature ChipscopePro(D403299BA828)
16:28:17 (xilinxd) Disabling 1 license from feature Embedded_Edition(D403299BA828)
16:28:17 (xilinxd)      /etc/flexlm//DalekIseFloat.lic
16:28:17 (xilinxd) Disabling 1 license from feature ChipscopePro(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature ChipscopePro_SIOTK(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature Embedded_Edition(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature ISE(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature ISIM(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature PlanAhead(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature sdk(BA0205146913)
16:28:17 (xilinxd) Disabling 1 license from feature xps(BA0205146913)
16:28:17 (xilinxd) EXTERNAL FILTERS are OFF
16:28:17 (lmgrd) Started xilinxd (internet tcp_port 40927 pid 5554)
16:28:17 (lmgrd) xilinxd using TCP-port 40927
16:28:17 (xilinxd) No valid hostids, exiting
16:28:17 (xilinxd) EXITING DUE TO SIGNAL 34 Exit reason 2
16:28:17 (lmgrd) xilinxd exited with status 34 (Invalid host)
16:28:17 (lmgrd) Please correct problem and restart daemons
Tags (3)
Re: Wrong hostid on SERVER line for license file
You need to regenerate your license to target the new host id.
1. Proceed to the Xilinx Product Licensing Site www.xilinx.com/getlicense
2. Click on the “Manage Licenses” tab.
3. Highlight the license file entry for the host you wish to update
4. Click the “Modify License” button
5. Update the host information on the corresponding screen.
If you donot know the account details of your organisation you can contact xilinx customer support by filling the form at http://www.xilinx.com/askx/customer_service_form.htm
Deepika.
Deepika.
License was generated with the host id: 000acd1896b2. But your currrent hostid is: 6805ca18b7d2
Use this command to get your hostid: lmutil lmhostid
