XPS: Application tab missing!
Hi, I had an error free Embedded edition installed on my Linux box. However, when i open XPS i don't see the " applications" tab in the project area. I can see 'IP Catalog' and 'Project'. I dont have the option for application in "View" either. The tutorial for EDK (edkctt), says that it should be visible once i am through with BSB).
Can anyone suggest what the problem could be?
Should i reinstall the complete package or
would it suffice if i install the standalone SDK (if that is the issue)
>> Praveen Mayakar
This is the intended behavior. All the software applications should be done in SDK environment.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/platform_studio/platform_studio_start.htm
FYI: This is for 13.1 version
cool, thanks. The help documents need to be updated in this case, as they are misleading otherwise.
