mishal_goel
Xilinx ISE 3.3SP3 Download Issue
I downloaded Xilinx ISE 3.3SP3 from the ISE Archive and encountered 2 issues.
1) When downloading from the website (https://www.xilinx.com/downloadNav/vivado-design-tools/archive-ise.html), it downloads Xilinx version 9.2i.
2) When I try to run iMPACT, I get the following error: The procedure entry point ??9PathListIterator@Port@@QBE_NABV01@@Z could not be located in the dynamic link library libPortability.dll
The 2nd error is more critical for my operations, so any help would be greatly appreciated!
Thanks!
drjohnsmith
Wow thats old,
which OS are you trying to run it on ?
it certainly wont run on W10 , and I doubt W7 ,
mishal_goel
The computer is running Windows XP.
ansarimo
Hi @mishal_goel
Thanks for confirming the OS, the following AR lists the supported OSs for the corresponding ISEs:
https://www.xilinx.com/support/answers/18419.html
Instead of using ISE 9.2, I would recommend using ISE 14.7 as it can be installed on Windows XP pro.
If you only want to use IMPACT and Chipscope pro, you can download and install the Lab tools of ISE 14.7 instead of downloading the entire SW.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/archive-ise.html
Hope this helps.
Thanks & Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
