07-08-2013 04:37 PM
pstelian2011 wrote:Quite unusual from xil, in place of fixing the problem they forbid you to start the app in win8!? :(
The "they" is not Xilinx, it's Microsoft.
One of the rather more difficult things for a developer to handle in Windows 8 is all of the new permissions requirements. And the reason why a lot of older software doesn't run in Windows 8 is because they don't know anything about that stuff.
Developers have to go in and add it. And that's easier if the application was written in .NET or whatever standard Windows thing from the beginning. The Xilinx tools are cross-platform (they run on Linux as well as Windows) so the translation layer which allows that all to happen has to be updated to support Windows 8. That likely hasn't happened yet, or if it has, Xilinx still hasn't been able to implement it.
I bet it's a vexing programming issue.
My WAG is that 15.1 or upcoming versions of Vivado will support Win8.
Which we have no intention of using until lots of hardware support issues are resolved and they get rid of that godforsaken **bleep**ty interface.
08-31-2013 10:24 AM
the setup file in nt folder in bin also did not work for me.i have a windows 8 hp pavillion laptop.i just cant get this installed on my comp.
plz help.
@hanismarty wrote:
EVERYONE, to make Xilinx work in Windows 8, lauch the ise.exe from the ''nt'' folder which is for 32-bit not ''nt64'' and download ModelSim Simulator, there is a free student version you can use since iSim doesnt work on windows 8.
in brief, on Windows 8, run Xilinx in 32-bit with ModelSim instead of iSim.
I tried it and it worked!
09-01-2013 09:22 AM
me too. Have you solved that problem yes? If yes, can you tell me the way?
Thanks in advance,
09-02-2013 06:26 AM
I also have Windows 8 and installed Vivado. The installation went fine, license manager bugged a bit but found a workaround.
I can start Vivado HLS, but I can't start Vivado. When I manually locate "Vivado.bat" and run it, it stops with "start_gui is not supported on Windows8".
Would rather not dual boot windows 7 AND windows 8 on a limited size SSD drive.
09-02-2013 07:37 AM
ok I tried a combination of things:
changed the desktop shortcut path from
"C:\Xilinx\Vivado\2013.2\bin\unwrapped\win64.o\vvgl.exe C:\Xilinx\Vivado\2013.2\.\bin\vivado.bat"
to
"C:\Xilinx\Vivado\2013.2\bin\unwrapped\win32.o\vvgl.exe C:\Xilinx\Vivado\2013.2\.\bin\vivado.bat"
then I went to the vivado.exe located in the win32.o folder and changed compatibility mode to Windows 7.
Used the shortcut on the desktop again and got Vivado to start.
So far I've only tried opening an example project, and creating a new project myself, so I don't know how much of the program will work. So far so good at least.
10-20-2013 07:05 AM
This worked! Thanks
10-20-2013 09:43 AM
12-20-2013 04:46 PM
Thanks rafaelcatrou, you saved my life! I have an assignment due in a few weeks for university and needed to work with my Spartan 6 FPGA at home. Because of you I will pass this module!
01-15-2014 03:14 AM
Hello guys,
Help needed.
USB cable is not working in Windows 8 for IMPACT
When I try to initialize the chain I get :Error:IMPACT 923 Can not find cable,check cable setup
In Windows device manager , I get "The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)" when i try to install the driver.
I am using ISE 14.4.
Please help me out.
01-15-2014 03:16 AM
01-15-2014 03:32 AM
01-28-2014 09:53 AM
Does anyone have tried to install Xilinx 14.7 on Windows 8 ?
I'm having several errors of the type:
ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "_GetPropertyType"'.
Both with 32 and 64 bit ISE versions.
Does anyone have an idea on how to solve the issue ?
Many thanks,
- Mauro.
01-28-2014 10:00 AM
01-28-2014 11:42 AM
I suggest you do a search here. This question has been asked and answered about 125 times.
03-18-2014 10:22 AM
This is the problem I am facing too. I tried installing ise 13.1 and have the exact same issue. _xsetup.exe stops working. Please help.
04-04-2014 12:45 PM
Follow the link. problem solved.
04-10-2014 02:21 AM
particle,
I would like to extend my thanks! I just spent the last 2 hours troubleshooting this issue and ended up uninstalling/reinstalling Vivado and ISE several times before stumbling upon your fix, which worked flawlessly on the first try. Way to go!!! Saving my life, one comment at a time, lol.
--Wonderwill
05-21-2014 12:07 PM
Thank you for these suggestions, they were very helpful to me. I was able to get ISE running with the libPortability.dll replacement trick.
Planahead still crashed on me, but I believe I have found a solution. It was failing at the point where it starts the GUI, and I was getting the Java error others have reported. The solution, like the other fixes, seems to be forcing it to load in 32-bit.
Edit the file: C:\Xilinx\14.7\ISE_DS\PlanAhead\bin\loader.bat
Look for this section of code in the loader.bat file:
set RDI_OS_ARCH=32
if [%PROCESSOR_ARCHITECTURE%] == [x86] (
if defined PROCESSOR_ARCHITEW6432 (
set RDI_OS_ARCH=64
) else (
if defined PROCESSOR_ARCHITECTURE (
set RDI_OS_ARCH=64
And remark out all the lines after the first one, like so:
set RDI_OS_ARCH=32
rem if [%PROCESSOR_ARCHITECTURE%] == [x86] (
rem if defined PROCESSOR_ARCHITEW6432 (
rem set RDI_OS_ARCH=64
rem )
rem ) else (
rem if defined PROCESSOR_ARCHITECTURE (
rem )
rem )
This allowed Planahead to launch and so far has been working fine.
Hope this helps others who are trying to use Xilinx in Windows 8.
Cheers,
Frank Cheung
06-16-2014 03:03 AM
brilliant - thanks
06-16-2014 03:13 AM
Despite sometimes is not working, many other works...which is a great advance compared to...nothing up to now besided Xilinx.
So, great contribution Frank.
07-23-2014 09:18 AM
While using libportabilityNOSH.dll works for ISE, this is not an option for PlanAhead as it directly links SmartHeap.
However, Vivado 2014.1 and newer officially support Windows 8, and still use SmartHeap. This means the SmartHeap DLLs have been updated for Windows 8 in Vivado 2014.1+.
We can fix the issue completely by replacing the SmartHeap DLLs that come with ISE 14.7 with those from Vivado. The attached script will do this automatically if ISE is installed in the default path on the C: drive. If not, modify the path at the top of the script to point to the proper location.
I really hope Xilinx pushes out a patch to ISE that does this. It should not take much effort and would make it work on an operating system that's nearly two years old.
Hope this is useful!
09-30-2014 02:29 PM
I was able to get xilinx to work on 8.1 by following the same process of installing in the nt setup, however I cannot download to any boards for it can't find cable drivers. Any solutions?
10-01-2014 05:18 AM
10-12-2014 01:00 PM
I try to install ISE 11.1 on Windows 8, but when i double click on xsetup.exe, it simply don't run. And now what ? (I just downloaded it from Xilinx website and unzip it, without burning on DVD).
02-15-2015 05:55 PM
This is just a general comment, but I am trying to do a project with a older Spartan FPGA. My computer runs Windows 8.1. I have had nothing but trouble, so I am giving up. This thread has been around for TWO YEARS, and still ISE does not oficially support Windows 8. I can't use PlanAhead because, for some unknown reason, you cannot make Coregen DCM modules using PlanAhead -- only ISE (and I had to google why the hell I could not have Coregen make a DCM in PlanAhead). What a mess!
Here is my impression of Xilinx:
"You have a new OS, but want to develope for older hardware? SCREW YOU!"
No, I am not a high-volume customer right now. I am a "hobbyist" having fun at home in the evenings, but my day job is to use my MSEE to help design custom silicon for a well-known company. Now, to figure out how to unload my three or four Xilinx FPGA boards on some unsuspecting fool and get some Altera Boards, where they know how to make software that works.
Yes, I am pissed. I wasted several hours trying to get the ISE simulator to work -- time that I could have been using to work on my design, or spend time with my wife and kids. The "Windows 8 is a new OS" excuse worked well two years ago, but not any more. Would it REALLY be that hard to shoe-horn support for Virtex and Spartan devices into Vivaldo?
I got my start making a FibreChannel display board using a Virtex 2. A few years ago, I was prototyping an ASIC for a network device using a Virtex 5 (thanks for the built-in SERDES). It was fun while it lasted, Xilinx, but I sense your lack of commitment to our relationship.
Sorry for the rant, but I am just tired of banging by head against the wall trying to use these stupid FPGAs. The next time I buy an FPGA board, it will NOT be from a company that I know will drop support whenever they feel like it.
02-26-2015 05:26 PM
D235J's solution works for me. Seems to have fixed everything that was wrong with 14.7 under win 8.1... Thanks!
03-01-2015 07:49 PM
Thanks for this post :)
05-29-2015 08:33 AM
Thanks d235j. Despite all the suggestions of fixes for ISE. I found it difficult for any help with EDK(xps) on Windows 8. i manually tried the portability fix but that didn't fix it. Your magical fix made everything work. Shame that that script couldn't of been added at the end of the standard install from xilinx. It would of saved a lot of people a lot of hastle. Thanks again.
05-29-2015 01:53 PM
The fix is great.
However, be sure to unzip it in a path with no spaces or the batch file will fail.
08-21-2015 01:31 PM
Hey guys. please help me.. i got tdownload zip file posted by d235j but i am not getting it that where i have to place and where i should save... and i am getting error of
_pn.exe has stopped working
