taylo019
Xilinx ISE licensing error
Hello. I am trying to activate my license for Xilinx Design using the xml license that was emailed to me. Whenever I attempt to load it, it gives the error:
Unable to load License Rights into Trusted Storage
Any ideas on how I can get this to work? Thank you for reading!
vuppala
There are two ways to obtain license.
1. Contact the person from whom you received this kit (i.e., Xilinx university program team), they may help you.
2. Otherwise, purchase a new license.
Vinay
pulim
You can't use activation license (.xml file) to use with ISE.
You need to use certificate based license (.lic) file to use with ISE. This .lic file you need to generate from Certificate based Licenses section in your account.
vuppala
Hello @taylo019
Vivado uses activation based licenses i.e., .xml licenses.
ISE design suite uses certificate based licenses. i.e., .lic licenses
Vinay
vijayak
Can you please post the full error message?
Thanks,Vijay
taylo019
Thank you all for your responses.
pulim and vuppala, I understand now. Thank you for the information.
vijayak, the error message that I'm receiving is copied in my original post in full.
The device that I'm trying to work with is the LX110T FPGA on the XUPV5-LX110T evaluation platform for research. The Webpack license of ISE doesn't allow this device to be used. I read in documentation that Vivado would not work for Virtex-5 FPGAs. Perhaps I was given the wrong license? How would I obtain an academic license for ISE so that I can use the Virtex-5 LX110T device in ISE?
Thank you all for your help.
vuppala
Vinay
taylo019
Thank you vuppala. I will work on this.
rose_gomar
Hello
I am also unable to load .lic file, when I open lISE license manager there is a copy button, when I press that the license manager closes and nothing happens!
Could you please help to solve this issu?
anatoli
Hello @taylo019 ,
Please raise your issue in a separate/new forum post, as this a really old topic that is now closed.
Please raise your question on Xilinx Installation and Licensing forum board here: https://forums.xilinx.com/t5/Installation-and-Licensing/bd-p/INSTALLBD
Xilinx Community can help you with your issue then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
