aliraheem94
Xilinx System Generator not configure matlab
Hi every one ,
When I want to configure Matlab 2013 with ISE 14.7
I got this error message (see attachment)
please help me to solve it
with snapshot description
regards
balkris
try with administrative privilege
check this ARs as well
https://www.xilinx.com/support/answers/17966.html
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
aliraheem94
I got this error when open Matlab after configure Xilinx ise ,  display the solution with snapshot please
Warning: Cannot find path "C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64" in "PATH" environment.
Cannot find path "C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64" in "PATH" environment. The libraries under the path are needed
to simulate and netlist designs using blocks from Xilinx System Generator for DSP blockset.
Cannot find path "C:\Xilinx\14.7\ISE_DS\PlanAhead\bin" in "PATH" environment.
To make sure that your design simulates and netlists with Xilinx blockset as expected it is required that you start
MATLAB using "Xilinx Design Tools\ISE Design Suite 14.7\System Generator\Sysgen Generator" from All Programs menu
under Windows Start button.
balkris
how are you invoking sysgen . The correct way is it is required that you start the MATLAB using "Xilinx Design Tools\ISE Design Suite 14.7\System Generator\Sysgen Generator" from All Programs menu
short cut just below matlab configuration on above snap shot
Thanks and Regards
Balkrishan
aliraheem94
you mean that when I want to start Matlab , from system generator as administration  , not from matlab shortcut??
thanx alot
for help me
balkris
use the short  cut with administrative access  as mention in snapshot
Thanks and Regards
Balkrishan
