abhishek.chevli
Xilinx Vivado 2019.1 License
Two issue I am facing with lincesing:
  • Generated Licenses are not visible in 'Manage License' tab on Xilinx getlicense portal.
  • License Voucher was partially redeemed and because of this, I am not able to redeem the same voucher to generate rest of the licenses.
Please note: Voucher was initially redeemed using non-admin Xilinx account.
Please help.
Abhishek
anatoli
Hello @abhishek.chevli ,
For these issues, you’d need to open a new SR under the LICENSING section in Service Portal (https://www.xilinx.com/support.html#serviceportal). Xilinx Customer Service team will take care of these issues for you then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Kind Regards,
Anatoli Curran,
Versal Blogs
