Xilinx Vivado License
Hello Xilinx Community,
i use the Webpack Free Version of Vivado and i wanna buy a Zedboard with a license.
What is the different between the free license and theVivado HL System Edition and the other license?
i find this webpage: https://www.xilinx.com/products/design-tools/vivado.html#buy
I know i get more tools when i use other License but:
My Question is support all License multicore CPUs like Ryzen 3900x? is the Free Webpack License slower like use only 1 or 2 Cores of the CPU and no more?
Best regards
Jeko
Re: Xilinx Vivado License
Hi @jeko91 ,
1) The only difference between Webpack license and System Edition is webpack supports only limited devices.
for example I'm using Trenz TE0745(ZYNQ XC7Z7030). My chip is in this limited list and I can use webpack edition.
I can run 8 cores without any problem. There is no performance restriction.
Vivado HL WebPACK Edition only supports the following devices: Zynq UltraScale+ MPSoC (XCZU2CG/EG, XCZU3CG/EG), Zynq®-7000 All Programmable SoC (XC7Z007S – XC7Z7030), Spartan-7 (XC7S50), Artix®-7 (XC7A15T, XC7A35T, XC7A50T, XC7A75T, XC7A100T, XC7A200T), Kintex®-7 (XC7K70T, XC7K160T) , Kintex UltraScale™ (XCKU025 – XCKU035) and Kintex UltraScale+ (XCKU3P, XCKU5P)
In time, this list can be changed but point is that.
2) About buying a Zedboard with license. I have also ZC702 evaluation board and it came us with a license, device locked(you can use this license only with this board) and 1 year duration. I recommend you, before buying a license controlind, it comes a license or not.
3) Other license type is Avaluation, it also has full permissions, but expires in 1 month.
Hi @jeko91 ,
thank you! I gonna use the xilinx 7020 and its not a problem for Webpack.
Hi again,
Are you sure 7020 is in this limited list?
ZC702 has also 7020, but I did not see it in this list. Maybe it is updated, I do not know.
i think so because you said : Zynq®-7000 All Programmable SoC (XC7Z007S – XC7Z7030)... and between the Zynq 7000 to Zynq 7030 is the Zynq 7020.
I use the: xc7z020clg484-1
Or i am wrong?
You are right. Yours is in the list.
