Observer arasch
ZC706 Vivado board files
I am using Vivado 2018.2 and have a ZC706 Evaluation Kit.
Starting a new project I can't find ZC706 among the board files. Looking in C:\Xilinx\Vivado\2018.2\data\boards\board_files I also don't see zc706 anywhere (the closest seems to be zc702).
Is there a place I can get the ZC706 board files from or do I need to use ZC702 files?
Re: ZC706 Vivado board files
Hi Arasch,
No Xilinx account should not matter. If you select the device while installing vivado then it should be added to the installtion.
I can see only few boards.
As per the options I would see more boards of 7 series/ultrascale/US+/zynq/zynq mp in the below snapshot.
But somehow you have one of different categories. Please try to re install and share the update. Also make sure you have installed the system edition in order to use this part. ZC706 is not supported for webpack version of tool.
Harshit
Can you try to add the 7 series zynq devices and see if anything changes. Here is the AR https://www.xilinx.com/support/answers/60112.html
I can them in 2018.2. Please use the above steps to include them and it should be there.
Harshit
Observer arasch
Thanks @harshit
For some reason if I try any of the options (also as Admin):
  • Launch the installer using the shortcut Add Design Tools or Devices located with the other installed shortcuts on Windows.
  • Launch the installer from within the Vivado IDE menu (Help -> Add Design Tools or Devices)
  • Launch the installer from within the .xinstall directory of an existing install. (for example: C:\Xilinx\.xinstall\Vivado_2014.1\xsetup.exe)
Then the below Xilinx logo pops up.
But after few seconds disappears again without anything happening.
Arasch
Hi arasch
This might happen if Vivado is running in the background. Generally it issues the warning.
You can try to close all the current vivado session and go to start> xilinx> add device and tools( run as admin).
You can also try to use web installer to install 2018.2 additional device. Here is the link
https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_Vivado_SDK_Web_2018.2_0614_1954_Win64.exe
Harshit
Observer arasch
Thanks for your help @harshit
I tried the "Add Design Tools or Devices 2018.2" while having stopped Xilinx running in the background. But still get the same result (The logo pops up and disappears, but then nothing happens...)
Then I tried your link, but get the error that the file requested is not available.
Maybe I should remove the full Vivado and reinstall ? Just take really long...
Observer arasch
Correction:
When I copy and paste your link into the browser it brings me to the right place.
Unfortunately it does not work when I run the installation executable that starts than.
Looking thorough the installed Xilinx files I found that the zc706 folder is available under C:\Xilinx\SDK\2018.2\data\boards\board_files. But just copying that folder to C:\Xilinx\Vivado\2018.2\data\boards\board_files did unfortunately not yet solve my problem.
I also today installed Vivado on a (bigger) Linux machine and had to find out that I have the same issue there: no zc706 board files.
Is that because I am using in both cases the same Xilinx account for the download??
Observer arasch
Hi @harshit
in below screenshot I copied manually the zc706 folder from the SDK foder to the Vivado folder.
But even though the files in the zc706 folder have similar structure as the other board files in C:\Xilinx\Vivado\2018.2\data\boards\board_files
Vivado doesn't pick up the zc706 and does not show the Board for selection.
I installed Vivado on two separate machines - one Windows 10, one Linux - and both show the same results.
Is there any way to fix this?
Thanks for any hints...
Hi Arasch,
Harshit
Observer arasch
Hi @harshit
That might be my mistake --- being used to the Zedboard I assumed I have to install the WebPack.
I will deinstall and install the system edition. Once done I'll let you know.
