design_linking license for OSD
The osd license status shows as  design linking license. How do I change it in to hardware license. I am using vivado 2018.2.
Jothi
Re: design_linking license for OSD
Hello @jothiadithya,
Have you actually obtained a Hardware Evaluation license for this IP Core yet? If not, you can obtain this by navigating to www.xilinx.com/getlicenses and then, you can obtain this from the "Evaluation and no Charge Cores" section as shown below:
FYI - please view this page, https://www.xilinx.com/products/intellectual-property/ef-di-osd.html#overview, where you can read a note that indicates that Video On-Screen Display will get obsoleted in 2019.1 version of Vivado and won't be recommended for any new designs.
As a replacement, users can use a license-free an IP Core, called Video Mixer and it is bundled with Vivado 2018.3 (onwards).
For more info regarding this IP Core, please read the Product Guide 243: https://www.xilinx.com/support/documentation/ip_documentation/v_mix/v3_0/pg243-v-mix.pdf
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
