es1 zcu102 in vivado 2018.3, add boardfiles, modify?
Is it possible to modify the boardfile or somehow use es1 for zcu102 in vivado 2018.3? I need to use this latest tool together with my old chip es1 zcu102. I know earlier 17.4 support this es1 with license and boardfile together with init.tcl. However I need the later 18.3 to be used.
Thank you
Re: es1 zcu102 in vivado 2018.3, add boardfiles, modify?
@sudo
You can copy the board files in the installation folder of 2018.3 (<install_dir>/Vivado/<version>/data/boards/board_files)
Check Appendix A in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug895-vivado-system-level-design-entry.pdf#page=100
--Syed
Hello @sudo,
As this is in relation to XCZU9EG-ES1 part, you won't be able to target this part in 2018.3 version of Vivado.
2017.4.1 is the last Vivado release that supported ES1 silicon of this part. Therefore, to be able to design targetting XCZU9EG-ES1, please use Vivado 2017.4 or earlier versions of Vivado, as in 2018.3 you can only use XCZU9EG (i.e. a production part) or XCZU9EG-ES2, but not ES1.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Is it not possible at all to use board files es1 and set init.tcl for vivado 18.3 to use es1?
How can I force vivado and sdk 18.3 to load bit, mcs, jtag debug for XCZU9EG es1 desbite the design is run, created for XCZU9EG?
The answer for the first question above is NO, as there nothing to enable, as ES1 parts are not there, unlike with 2017.4. With 2017.4, with a valid ES1 license file, together with Vivado_init.tcl command in place, yes, this will enable to XCZU9EG-ES1 device for you, however with 2018.3 - this is not possible. You can test this yourself, and you'll notice then that your won't find XCZU9EG-ES1 part in 2018.3.
For your second question, we cannot guarantee what will happen if the wrong version of the bitstream is used for the different version of silicon.
We would always recommend using the files that correspond to the correct silicon version, as they wouldn’t have been tested otherwise.
 Really, the production version of the silicon is a version that has fixed previous issues present in the ES silicon. So, it may be the case that using an ES bitstream on a production device will just not use all corrected features etc. Using the production bitstream on the ES device will more than likely not work, since the design may include features that are not present on the ES device.
Using the incorrect version of bitstream for silicon would be at the users own risk.
I hope the above is clear.
Kind Regards,
Anatoli Curran,
