get my purchased license
when I try to get purchased license for ISE 13.1 (the Fields marked with an asterisk * are required) I have filled all fields correctly and when press next this error is displayed "we can not fulfill  your request as your account has failled export compliance verification please visit http://www.xilinx.com/support/answers/44043.html " I try many many times please give me solution,also I try with different user name it is same.
my e_mail is e_a_mansour@yahoo.com
You can contact your FAE
Try to contact customer services
http://www.xilinx.com/support/service-portal/contact-support.html
Here is licesning FAQs
http://www.xilinx.com/tools/faq.htm
Thanks and Regards
Balkrishan
Hi @ahmedmansour
I just sent you a private message. Please check the same.
Thanks,Vijay
Hi @ahmedmansour
Did you follow the instructions given in the private message? Hope your issue is resolved.
Thanks,Vijay
