ke.deng
how to create license server
Due to the failure of the old license server, a new license server needs to be set up. How to migrate the license? Where can the server-side installation files be downloaded?
watari
Professor
Professor
Hi @ke.deng
What is your target OS ?
Best regards,
ke.deng
win10 pro 64bit
ansarimo
Hi @ke.deng
I suspect you want to rehost your license to a new server/machine, if yes, then follow the below steps:
1. The license server utilities can be downloaded from the Xilinx download page: https://www.xilinx.com/support/download.html
Scroll down to find License Management tools and as per your machine, download windows files.
2. Now your license files must have host-ids of the old machine(please check for host ids of the license file and Machine on which you will be hosting license server), If host-id has to be changed then follow the below steps from the UG: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug973-vivado-release-notes-install-license.pdf#page=30
3. To set up a new license server, refer to the following UG for detailed steps: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug973-vivado-release-notes-install-license.pdf#page=26
Hope this helps
Thanks and Regards,
Ansari Hunen
Don’t forget to replykudo, and accept as a solution.
