installer xilink ise 14.7 for linux
How do I install xilinx ise for linux? help me
@gigi
Check chapter 3 in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Download ISE from below AR:
https://www.xilinx.com/support/answers/57840.html
--Syed
also for the "web pack" version?
@gigi
For webpack, You need to select the webpack edition while installing.
Check chapter 3 in the ISE release notes link shared in my previous post.
--Syed
