ise14.7 xst.exe has stopped working
Recently, when I used K7 410T to instantiate srio_gen2_v1_7 under ISE14.7, xst.exe would stop working.
On my laptop, XST.exe stopped working directly without any error. But using my desktop synthesis will prompt XST.exe to stop working. The following diagram "problem1.jpg"。I click on the debugger
I didn't get that problem. Is there anyone who could help me with this?
Hi @zlzlql,
Please refer this AR#60449 for your issue.
Deepak D N
Please reply or Give Kudos or Mark it as  an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
I learned the reply from wzhlaliang in the question and answer section, but I couldn't open“Xilinx Answer 59851” .Can anyone open this document? Please send me a copy of my email kcg1221@163.com. Thanks very much 。
Hi @zlzlql,
Deepak D N
Deepak D N
Thanks very much! I refer this AR# 40377 . change Synthesis options: “read_cores”.problem is solved。
