mishal_goel
libPortability.dll Xilinx 3.3SP3
I am receiving an Entry Point Not Found error as a result of libPortability.dll - "The procedure entry point ??9PathListIterator@Port@@QBE_NABV01@@Z could not be located in the dynamic link library libPortability.dll"
Is there anyway to download this file separately without downloading the entire service pack? I am running Xilinx 3.3SP3 on a Windows XP computer.
anatoli
Hello @mishal_goel ,
Is there a reason why you need or must use ISE 3.3? Why not ISE 14.7 or even better, Vivado?
Anyhow, ISE3.3 is not supported on Windows XP and it is recomended to install and use a supported os with each release: https://www.xilinx.com/support/answers/18419.html
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
