Newbie paco21
libPortabilityNOSH.dll
I have a problem installing Xilinx because of compatability, i don't have libPortabilityNOSH.dll file in my directory
Re: libPortabilityNOSH.dll
Hello @paco21 ,
This type of a behaviour (i.e. missing library etc.) is normally a post installation behaviour. Were you able to install ISE (or Vivado?) and when you trying to run the tools, an error is given then of a missing library? Can you confirm on this and also on the exact stage where this error is seeing (at the beginning of the installation or at the end?)?
Please share this info in relation to the above as well as the info in relation to what are you installing (ISE or Vivado) and which OS is in your case?
If you have any questions for me, please let me know.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
