Visitor asmouch
licence installation problem
Hi ! I'm using windows7 64bits and I've a Node lock licence.
my board: virtexV ml 507.
I'm trying to generate the bitstream but it shows me this error:
At Local date and time: Tue Feb 26 10:12:16 2013
make -f system.make bits started...
"Creating system netlist for hardware specification.."
platgen -p xc5vfx70tff1136-1 -lang vhdl -intstyle default -msg __xps/ise/xmsgprops.lst system.mhs
Release 14.4 - platgen Xilinx EDK 14.4 Build EDK_P.49d
(nt64)
Copyright (c) 1995-2012 Xilinx, Inc. All rights reserved.
Command Line: platgen -p xc5vfx70tff1136-1 -lang vhdl -intstyle default -msg
ERROR:EDK - INFO:Security:71 - If a license for part 'xc5vfx70t' is available,
it will be possible to use 'XPS_TDP' instead of 'XPS'.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to
'1234@server;D:\PFE\Xilinx.lic'.
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to
'D:\PFE\bin\nt64\lmtools'.
INFO:Security:68 - For more information or for assistance in obtaining
a license, please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is Asmouch, on host ASMOUCH-TOSH.
WARNING:Security:9b - No 'XPS' feature version 2012.12 was available for part
'xc5vfx70t'.
ERROR:Security:12 - No 'xc5vfx70t' feature version 2012.12 was available
(-96),
so 'XPS_TDP' may not be used.
License server machine is down or not responding.
See the system adminstrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Feature: XPS
Hostname: server
License path:
1234@server;D:\PFE\Xilinx.lic;D:\PFE\bin\nt64\lmtools;C:/.Xilinx\Xilinx.lic;C
:\Xilinx\14.4\ISE_DS\ISE/coregen/core_licenses\Xilinx.lic;C:\Xilinx\14.4\ISE_
DS\ISE/coregen/core_licenses\XilinxFree.lic;C:\Xilinx\14.4\ISE_DS\EDK/data/co
re_licenses\Xilinx.lic;2100@server;C:\Xilinx\14.4\Xilinx.lic;
FLEXnet Licensing error:-96,7
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".License server machine is down or not
responding.
Feature: xc5vfx70t
Hostname: server
License path:
ERROR:EDK:440 - platgen failed with errors!
Done!
what can I do to fix this problem???
L'enfer, c'est l'attente sans espoir
"Hell, it's hopeless waiting"
Observer heber.green
Re: licence installation problem
The errors look like your LM_LICENSE_FILE enviornment variable is pointing to the wrong place. Have you checked out this page yet?
http://www.xilinx.com/support/answers/42406.htm
Best of luck,
-Heber
