altium_chou
licens issue
Hi~
Because I change my lab computer, I want to delete my last host named "...-i9...".
But the system show I exceed the maximum value that I can operate.
So. Someone can tell me how to reset all the setting (or just delete all host)?
It is so exhaust that I think reset is better decision.
thanks
ansarimo
Hi @altium_chou
I suspect you have reached the maximum limit of rehosts, are you facing the below error while rehosting?
If yes, then as indicated in the message, you'd need to raise an Electronic Fulfillment SR with the Xilinx Customer Service team (by logging in to https://www.xilinx.com/support.html#serviceportal -> LICENSING), asking them to add you move of these re-host attempts. They will then be able to reset the counter back to 0 out of 5, so you'd then be able to re-host your licenses.
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
