09-26-2012 11:35 PM
I am using Xilinx ISE 13.2 to implement logic design selecting virtex 6 and virtex 7 devices.I have implemented the design by targetting virtex 6 successfully. But I am not able to implement the design for virtex 7 device.I got map error that this virtex 7 feature is not available for ISE and problem encountered to get license for this architecture.
How to get license file for virtex-7 feature inorder to implement logic design using ISE 13.2 ???
09-26-2012 11:47 PM
Hi Deepak,
It seems you are using webpack license with ISE 13.2.
ISE webpack license do not support virtex 7 devices. for supported devices, have a look at http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_2/irn.pdf
09-26-2012 11:58 PM
I have gone through this ISE 13.2 user guide. In that they have mentioned virtex 7 devices are visible but require license to implement .Virtex 7 devices are license controlled.
Whats the solution for this ?
09-27-2012 12:09 AM
License type is node locked .
09-27-2012 08:43 AM
Hi Deepak,
As mentioned, virtex 7XT and Artix 7 devices require a special (device locked) license to use with ISE 13.2.
09-27-2012 09:04 PM
You should really be using the latest tools (i.e. 14.2 for 7 series designs).
10-03-2012 04:48 AM
Thanks. But how about to use ISE 13 .3 ???? I have read that this supports virtex 7 series .
can i get license for virtex 7 series to use it in ISE 13.2 ???
If there is no way then i will go for 14.3 only.
10-03-2012 05:16 AM
Hi Deepak,
ISE 13.3 supports virtex 7 devices. But I would recommend you to use ISE 13.3 if you have a proper license instead of using ISE 13.2.
Vinay
10-10-2012 02:04 AM
10-10-2012 05:28 AM
Can you please attach your license file here so that I can check and let you know why it is not working..
