license management in Vivado
Hi Team,
           I am trying to install vivado license on virtual machine ubuntu 12.04.
I am selecting "get free Licenses- Vivado_Webpack,sdk,free IP and more
"Pressting the "connect now"",
It should traverse to xlilix link for further steps.
But nothing is working. Can you please help.
Maha
Re: license management in Vivado
Currently Activation based licensing is not supported with Virtual machine.
Check this AR#http://www.xilinx.com/support/answers/60485.html
FYI.. Ubuntu is not supported OS.
Only these Operating systems are supported with Vivado 2014.2
Hi Manusha,
       Any older version of Vivado is suuported Ubuntu virtual machine?
Maha
No.. Ubuntu is not supported with any of Xilinx tools.
                 Why Xilinx tools are not supported in VM’s ? Is it intentional or this is something you haven’t tested so for Virtual machine ?
Maha
From 2014.3 activation based licensing is supported with Virual Machines(tentatively).
In earlier versions it is not tested on Virtual Machines.
Hello @dacu,
yes, Unsupported mostly like not tested or recommended.
But few customer workaround the tool to work with Ubuntu.
Xilinx won't guarantee if it work or not.
Yash
