Visitor nauen_lab
license not found
Hey everyone I know this is a pretty common issue but the ISE software (14.7) doesn't seem to recognize the license file. I tried installing the XLCM but that also seems to not be working.
I have the license file installed right on the desktop and have the PATH variable correctly installed to search for it there but Project navigator is still unable to verify the license.
Any help would be appreciated.
Thank you in advance!
Re: license not found
Hello @nauen_lab ,
Is this a floating license or a Node-Locked license?
Can you please generate an Xinfo report (in ISE) on that particular PC where you see the licensing failure and attach a copy of it for examination please, thanks? To generate Xinfo, Go to Start->All Programs->"Xilinx ISE Design Suite"->Accessories->XInfo System Checker.
We will examine these files and will get in touch with you then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
