licensing problem
ihave this error when running map on that Virtex 7 device
ihave Xilinx ISE 14.2 working good
ERROR:Security:11 - No 'xc7v2000t' feature version 2012.07 was available for
'ISE'
Map:258 - A problem was encountered attempting to get the license for this architecture.
after some research i found that there is limitation on license or something is there any thing can fix this ?
Re: licensing problem
Yes, you can purchase a full license for the tools.
Please check below AR
http://www.xilinx.com/support/answers/51510.htm
You can also check the supported 7 series devices with ISE 14.2 in release notes which is available at
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/irn.pdf (page #6).
Ashish
Moving to Licensing board.
Thanks,Vijay
