Visitor ekanshshukla
not able to find my board virtex VC707 in vivado 2015.4 and vivado 2019
hi..
i am noob in this feild, just following this This tutorial :: but i am unable to find my board (Virtex VC707) in the select board section. I tried in Vivado 2015.4 and 2019 but. Please help " Is there any way to add my virtex VC707" board in the list of boards in vivado.
Re: not able to find my board virtex VC707 in vivado 2015.4 and vivado 2019
Hello @ekanshshukla,
VC707 comes pre-loaded with the Vivado installation.
What Vivado Edition is in your case? Is it Vivado System Editions, i.e.:
Perhaps you've installed Vivado WebPACK edition, which is a device limited edition, so won't include this board with the installation, as 7vx485t isn't WebPACK supported device.
Also, if this is a System Edition, do you actually have Virtex-7 family selected to be installed with the main installation, as shown in my example above? Can you confirm on this please? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Scholar u4223374
What license are you using?
If it's the one that came with the VC707 - that gives you access to versions one year from when you activate it. So if you first activated it in, say January 2013, it'll only support Vivado versions up to 2013.4 (2014.1 wasn't available by January 2014).
If it's the free WebPack license, then it doesn't support the VC707 at all. You'll need to organize a new license.
how to organize a new license to make my VC707 Virtex Work with Vivado 2015 ( I installed vivado 2019 as web pack version and 2015 as full version).
I get Vivado 2012 with in Disk with my Virtex kit. ( and I am not getting any tutorial to get start with Vivado 2012. )
Scholar u4223374
Unfortunately the way to get a new license is "spend a lot of money". Roughly $3000 US for a Vivado Design Edition license.
Alternatively, if you don't need the VC707 (it's way more power than you need for just learning FPGAs), you could buy a cheap development kit like the Digilent Arty. That works with the free Vivado WebPack license.
Kind Regards,
Anatoli Curran,
Hello @ekanshshukla ,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
However if your issue is resolved now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Kind Regards,
Anatoli Curran,
accepted as solution, thank you
