Visitor 108953
problem installing 10.1.03 IP update on windows xp 64-bit
For RAM requirements more than 2 GB in our design (ISE 10.1.03), we need to change windows xp 32 bit to 64 bit version. First, we installed 10.1.03 successfully. But while trying install IP update of 10.1.03, we have encountered an error which is :
"This update can not be installed, as one or more of the system requirements are not met:
required product : ISE
required configuration :
required type :specific
required version : 10.1.03 "
I can't understand what the problem is? Can anyone please help us? Thanks.
Re: problem installing 10.1.03 IP update on windows xp 64-bit
http://www.xilinx.com/support/download/index.htm
Check out version "10.1 SP3". There're separate installers for 32-bit and 64-bit windows.
Have you applied SP3 for 64-bit windows?
There're separate service pack installation files for 32-bit and 64-bit windows.
Visitor 108953
There is no sp3 for windows xp 64bit. There is only sp3 for 32 bit. We have sp2 installed in our computer.
Visitor 108953
Thank you very much. We have successfully installed 10.1.03 update and also ip update.
But now when we make ise run on our old project (newly created project but has old vhdl and coregen files), we encounter an error report in synthesis which is :
Error signature
EventType: BEX64 P1:xst.exe. P2:0.0.0.0. P3:48bda5b0 P4:libXst_Flow.dll. P5:0.0.0.0. P6:48ac842e. P7:0000000000079ddc. P8:c0000409. P9:0000000000000000
What is the reason for this?
