Visitor groupeeseo
problems with system generator
hi everyone,
I installed sysyem generator to use it via matlab simulink (2013b)
My problem is that I do not see any xilinkx folder appearing in the matlab toolboox path, so I do not have acces to the system generator examples.
could you please help?
best
Re: problems with system generator
Have a look at the below AR
http://www.xilinx.com/support/answers/37022.htm
Satish
Do you configured the matlab using the system generator configurator.
Look at below links.
http://forums.xilinx.com/t5/DSP-Tools/system-generator-MATLAB-configuration/td-p/380921
http://forums.xilinx.com/t5/Virtex-Family-FPGAs/System-generator-configuration/td-p/296241
What is the version of ISE or Vivado you are using.
Satish
Visitor groupeeseo
thanks Satish for your answer
I tried to configure sysgen but it gives me always the error: failed the acces to temporary folder for writing...
Satish
Visitor groupeeseo
thanks satish!
This really helped, I also found out that sysgen examples in Matlab2013b using ISE design Suite 14.3 are stored in the directory:
C:/Xilinx/14.3/ISE_DS/ISE/sysgen
