ragistration id
ragistration ID given to me by offiicial website is showing that it is invalid when i enter it. what should i do now
Re: ragistration id
Hi @raichaitanya11,
The most probable cause for this error is that you are attempting installation on an unsupported operating system.
Can you please let us know which Software you are trying to install and on which OS?
Raj
Re: ragistration id
Hello @raichaitanya11,
Another reason for this error would be the fact that the Registration ID that you have obtain isn't the one that is compatible with your older version on an ISE that you trying to install. What version of ISE are you trying to install?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Re: ragistration id
9.2
Re: ragistration id
Can you confirm please, have you used the ISE Foundation 9.2 RegID found from this page and this RedID isn't getting accepted?
https://www.xilinx.com/member/10x_and_prior_regids.html#10x_9x
Kind Regards,
Anatoli Curran,
Re: ragistration id
Yes,I get tge registration ID from officoof xilinx website & it showed invalid registration ID
