system error SHSMP64.DLL
 i have download vivado 2017 in windows 7 . when i open the application i get a system error .dll missing and 0xc0000005  error.
how to resolve it.
Re: system error SHSMP64.DLL
I faced the same problem while installing other latest software too, where i could find updating windows helped me resolve this problem.
Hi @s.kishore1998
Check this thread:
https://forums.xilinx.com/t5/Installation-and-Licensing/Can-t-load-Vivado-15-1-on-Windows-8-1-SHSMP64-dll-is-missing/td-p/638039
Please note that with Vivado version 2017.x Visual C++ redistributable 2015 is used.
Rohit
Rohit
i am using vivado 2017.2
i cant resolve yet
Hi @s.kishore1998
If reinstalling didnot work. Can you please try with AR#59304 and see if it helps:
https://www.xilinx.com/support/answers/59304.html
If any other system which is having the working 2017.2 install, try replacing the particular dll in Vivado installed location with the one from working machine.
Also check this link:
http://www.fixerrorkit.com/fix-error/fix-SHSMP64.DLL-error.html
Hope the given suggestions help.
Rohit
Rohit
Hello @s.kishore1998,
I would like to check with you and see if you were able to resolve the issue? There are other customers who are also seeing the same error with 2017.2, so it would be great if we can identify the root cause of the problem and also a solution to this issue. Your help would be greatly appreciated and as this could help others with the same problem.
Thanks in advance and have a nice day.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Visitor robbietoo
I'm having this problem too. I found that I couldn't start directly through Vivado.exe.
You can refer to how default shortcuts Target and Start in as below, not directly to start Vivado.exe.
Target : C:\Xilinx\Vivado\2017.2\bin\unwrapped\win64.o\vvgl.exe C:\Xilinx\Vivado\2017.2\bin\vivado.bat
Start in: %APPDATA%\Xilinx\Vivado
If you want to find the exact update file, try installing photoshop 17 version. It shows similar error code and update required for rectifying error in their forum.
