trying to generate a new 30 day evaluation license
I am tryng to generate a new 30day evaluation license, but the license manager seems to be stuck on
"Waiting for Activation License".  When I go to the website, all of the Activation licenses are grayed
out, but the 30-day evaluation license is not listed.
My "current" 30 day evaluation license expired yesterday.
Is there a way to delete the 30 dya license that I see in the under the Manage Licneses Tab?
Re: trying to generate a new 30 day evaluation license
@creedxlnx
Use VLM(Vivado License Manager) to open Xilinx product site.
Anusheel
Helpful answer -> Give Kudos
@creedxlnx
Anusheel
Thanks. I don't know if you did anything to my account or not, but right after I posted this, I saw the "Return License to Xilinx" option in the license manager. After I did that, the Create New Licenses tab showed a grayed out 30-day Vivado License (progress). Using the license manager again to Obtain License seemed to clear it an I was able to generate and load a new license. Thanks again.
