petersk
update from xilind v11.6 to 11.13
I cannnot get the daemon to start with 11.13 of xilinxd, but the old one xilinxd 11.6 runs fine.  No changes to anything else as far as I can tell.  Anyone have any thoughts?  Here's the log messages:
17:02:00 (lmgrd) Since this is an unknown status, license server
17:02:00 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
17:02:00 (lmgrd) Using vendor daemon port 27010 specified in license file
17:02:00 (lmgrd) REStarted xilinxd (internet tcp_port 27010 pid 1962)
17:02:00 (xilinxd) FlexNet Licensing version v11.13.0.0 build 156845 x64_lsb
17:02:00 (xilinxd) SLOG: Summary LOG statistics is enabled.
17:02:00 (xilinxd) SLOG: FNPLS-INTERNAL-CKPT1
17:02:00 (xilinxd) SLOG: VM Status: 1
17:02:00 (xilinxd) SLOG: FNPLS-INTERNAL-CKPT2
17:02:00 (lmgrd) xilinxd exited with status 0 signal = 17
17:02:00 (lmgrd) REStarted xilinxd (internet tcp_port 27010 pid 1964)
17:02:00 (lmgrd) Please correct problem and restart daemons
vuppala
Hi @petersk
Share more information to debug the issue:
  1. Which OS are you using?
  2. Share your license file here.
Vinay
nupurs
If you are using Linux, try to run lmgrd.sh and see if it helps.
Nupur
Accept as solution if it resolved your query, give kudos if it led you to the solution.
Nupur
petersk
I'm using RHEL 6.4.
# ----- REMOVE LINES ABOVE HERE --------------------------
SERVER licenseserver C0521CC0521C 2100
USE_SERVER
VENDOR xilinxd xilinxd PORT=27010
#  This license is valid for evaluation ( 365 days ) from Thu Oct 29 14:54:24 UTC 2015
[kpeters@licenseserver storage]$ sudo head -n 20 xilinx.license.dat
USE_SERVER
INCREMENT PetaLinux_NoSuport_Eval xilinxd 2016.10 29-oct-2016 1 \
2CF269FE9AB3 \
VENDOR_STRING=petersk,PetaLinux_NoSuport_Eval,software,evaluation,_179461858_1777489045_0_701 \
ISSUER="Xilinx Inc" START=29-Oct-2015 TS_OK
# This is a permanent license generated on Thu Oct 29 14:54:24 UTC 2015
INCREMENT SDK xilinxd 2016.09 permanent 1 F6DFEE874915 \
VENDOR_STRING=petersk,SDK,software,permanent,_179461858_1777489045_210613675_528 \
vuppala
Hi @petersk
Looks like the issue lies in the VENDOR line of the license file.
Modify the following line:
To
VENDOR xilinxd PORT=27010
And then rerun the lmgrd process.
Vinay
nupurs
Also, keep one VENDOR line. Use this license file:
USE_SERVER
2CF269FE9AB3 \
Nupur
Give kudos(star on left) if it led you to the solution, accept as solution if it resolved your query.
Nupur
petersk
I didn't have two vendor lines.   That was probably me getting happy with the paste key.  I tried your suggestion, but cannot get V11.13 working.
I cannot go to 11.11 because our Intel license is version 12 and will not work with the earlier version.  We're currently running with version 12.
Kurt
vuppala
Hello @petersk
Are you getting the same error message?
Can you share the new lmgrd log file?
Also set the LD_LIBRARY_PATH to the location of Xilinx licensing libraries. It may help.
Vinay
