vivado 2014.2 suggest the same location of 2014.1 ?
hello
i got my DVD of Vivado 2014.2 , before this i installed the 2014.1 version near to 2013.4
in seach time, the installer suggest a locaion for installation, i have this ./vivado/
when i tried to install vivado 2014.2 , the installer suggest the same localtion of 2014.1 ?
so i doubt, that there is no difference between those to release !!
in other why, can i just update the 2014.1 via DVD 2014.2 ?
or just, i will modify the local manually ?
thank you
My blog : www.xilinx-video.blogspot.com
Re: vivado 2014.2 suggest the same location of 2014.1 ?
The installer points to the same location i.e.., ../vivado/ but it creates a separate folder with version i.e., ../vivado/2014.2
2014.1 and 2014.2 are complete separate installs.
Vinay
