ankitmahla
vivado timeout
i have currently installed vivado 2017.3 and during installation it asks us to give matlab access to it and i donot  have matlab.so it shows message of installtion successful with some error and then when i try to open vivado is shows Error when launching 'C:\Xilinx\Vivado\2017.3\.\bin\vivado.bat': Launcher time out
bandi
Hi @ankitmahla,
Which OS are you using?
Can you open command prompt and then run vivado.bat located in C:/Xilinx/Vivado/2017.3/bin/vivado.bat and share the output.
There is a known issue with VIvado 2017.3 and the Windows 10 Creators Update which might cause the issue, please check the following AR: https://www.xilinx.com/support/answers/69908.html
Also,check AR to debug: https://www.xilinx.com/support/answers/57386.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
