11-08-2016 07:28 PM
Do I need t have already purchased PlanAhead to use it with a Webpack license? I need to install ISE/PlanAhead 14.1 or newer for some maintenance on an existing Spartan6 design.
I set up a webpack license but I don't see anything about PlanAhead:
# ----- REMOVE LINES ABOVE HERE --------------------------
# This license is valid from Fri Nov 04 00:55:14 UTC 2016.
# This is license NODELOCKED to HOSTID=ANY;
# there is no need to run lmgrd for this license.
# This is a permanent license generated on Fri Nov 04 00:55:14 UTC 2016
INCREMENT SDK xilinxd 2017.11 permanent uncounted 3xxxx1F3BEB4 \
VENDOR_STRING=xxx,SDK,software,permanent,_210566005_0_0_405 \
HOSTID=ANY ISSUER="Xilinx Inc" START=04-Nov-2016 TS_OK
INCREMENT Analyzer xilinxd 2017.11 permanent uncounted Dxxxx48712CB \
VENDOR_STRING=xxx,Analyzer,software,permanent,_210566005_0_0_843 \
INCREMENT HLS xilinxd 2017.11 permanent uncounted 5xxxxF00C68B \
VENDOR_STRING=xxx,HLS,software,permanent,_210566005_0_0_521 \
INCREMENT V_WebPACK xilinxd 2017.11 permanent uncounted CxxxxA9813F3 \
VENDOR_STRING=xxx,V_WebPACK,software,permanent,_210566005_0_0_326 \
# ----- REMOVE LINES BELOW HERE --------------------------
I've seen other posts where people had the same issue but the answer was never documented. A contractor with PlanAhead did this design originally. Can I modify it with Webpack?
11-10-2016 06:22 AM - edited 11-10-2016 06:23 AM
That is correct. For some reason I could not access the ISE Webpack license via the license site so my FAE had to send me a license. The proper license looks something like this:
# This is a permanent license generated on Tue Nov 08 18:00:56 UTC 2016
INCREMENT ISE_WebPACK xilinxd 2017.11 permanent uncounted \
92xxxx1xxxx8 \
VENDOR_STRING=xxx,ISE_WebPACK,software,permanent,_151388_202xxx033_0_116 \
HOSTID=ANY ISSUER="Xilinx Inc" START=08-Nov-2016 TS_OK
# The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE ISE_WebPACK xilinxd 2017.11 xxxx2Fxxxx54 COMPONENTS="SDK \
ChipScopePro_SIOTK ChipscopePro WebPACK XC7Z010 XC7Z030 HLS \
xps_tdp XC7Z020 PlanAhead" OPTIONS=SUITE
No, you cannot use this license because the codes have been modified. You need to download the ISE_Webpack license or request a license from your FAE.
11-08-2016 08:49 PM
Hi @johndap
Which device are you targeting?
If you are targeting WebPACK device, then you need an ISE WebPACK (free) license.
Vinay
11-08-2016 10:00 PM
11-09-2016 04:44 AM - edited 11-09-2016 04:46 AM
@vuppala XC6SLX16-2CSG225 so the software_matrix.pdf says WebPack should support it.
11-09-2016 04:46 AM
@balkris - does your license specifically list PlanAhead?
11-09-2016 04:49 AM
Can you please share the xinfo report?
To generate xinfo file,
start menu start->Xilinx ISE design suite->Accessories->xinfo system checker.
It will generate xinfo.txt file. Please attach it here
Make sure you are pointing the Licenseing correctly.
Open the XLCM (start --> ISE Design Suite --> Accesories --> Manage Xilinx Licenses). Now enther the path to license file in XILINXD_LICENSE_FILE box (say C:/Xilinx_license/xilinx.ic) and click on set.
Syed
11-09-2016 07:44 PM
Hi @johndap
The license you pasted in your first post doesnt have ISE WebPACK license.
Since you are targeting WebPACK device, you have to generate ISE WebPACK license.
Vinay
92xxxx1xxxx8 \
