qile10234
write_bitstream ERROR
Hi,I'm sure I have install the v_cresample Hardware Evaluation.But when I Implementation it still appear ERROR: [Common 17-69] Command failed: This design contains a core for which bitstream generation is not supported:tutorial_i/zed_hdmi_display/v_cresample (v_cresample Version 4).Oh,the version of my vivado is 2014.2.
ashishd
Can you please try regenerating output products for the core and try again? To regenerate output products select below options by right clicking core –
1. Select “Reset Output Products”
2. Select “Generate Output Products”
Ashish
vemulad
Go to Tools --> Report --> Report IP status. In the IP status window you can find the license type used for generating this IP. If you see design linking here then try regenerating the IP output products and rerun the flow. Check if this helps.
If the above does not work, then run report_environment command  in Vivado TCL console and attach the log here.
Deepika.
Deepika.
ashishd
Ashish
qile10234
It workd !Thank you very much.
qile10234
I regenerator the core it works  thank you very much.
arttatran
I am getting the bit stream error for v_cresample is not supported......
but i have done these steps but not succeess.......
i have check the report that shows the design linking......
so plz help me in this regard if possible....
Thank u
Arttatran
ashishd
Hello @arttatran,
It is always recommended to open new thread for fresh query.
So with the new thread, attach the output file of below command -
report_environment -file <directory_name>/xinfo.txt
Ashish
anpingbo
I encounter the same problem, and tried to regenerate the outputs of hardware but didnot work........   do you solve this problem?
