davidg1992
xuninstall.exe doesn't work
I am trying to uninstall Vivado 2016.4 on my windows 10 computer. When I run the dedicated uninstaller, I get the Vivado splash screen, and then nothing. I saw that I was not the only person with this problem, but the only solution that I found was to manually delete the xilinx folder, reinstall, and then uninstall. Is this the only solution?
devinl
Community Manager
Community Manager
Hi @davidg1992,
Correct, if the xuninstall.exe and uninstall a program from the control panel does not complete, the only work around is to manually remove the directories including the AppData directory.
Thank you,
Devin
devinl
Community Manager
Community Manager
Hi @davidg1992,
Thank you,
Devin
anatoli
Hello @davidg1992,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
If not, and if @devinl answered your query, please mark Devin's response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then? We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
