09-13-2018 08:25 AM
I am trying to uninstall Vivado 2016.4 on my windows 10 computer. When I run the dedicated uninstaller, I get the Vivado splash screen, and then nothing. I saw that I was not the only person with this problem, but the only solution that I found was to manually delete the xilinx folder, reinstall, and then uninstall. Is this the only solution?
09-13-2018 08:45 AM
Hi @davidg1992,
Correct, if the xuninstall.exe and uninstall a program from the control panel does not complete, the only work around is to manually remove the directories including the AppData directory.
Thank you,
Devin
09-13-2018 08:45 AM
Hi @davidg1992,
Thank you,
Devin
09-18-2018 02:01 AM
Hello @davidg1992,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
If not, and if @devinl answered your query, please mark Devin's response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then? We appreciate your help.
