ERROR: "[DNNDK] Failure of DPU memory space used out" when trying to run DNNDK on Zynq-7000 platform
Issue:
I tried to run resnet50 DNNDK example on Zedboard following the DPU intergration flow with Vivado2019.1/PetaLinux2019.1 and met following error message:
[DNNDK] Allocate DPU memory space in size of [25534464 B]
[DNNDK] Failure of DPU memory space used out.
Sollution:
After increasing the debug level of DPU driver and add some debug print.
The issue can be located at:
unsigned long dpu_alloc_mem(uint32_t memsize)
	void *virtaddr;
	dma_addr_t phy_addr;
	struct memblk_node *pnewnode;
	memsize = (memsize + (PAGE_SIZE - 1)) & ~(PAGE_SIZE - 1); //at least one page frame
	virtaddr = dma_alloc_coherent(dev_handler, memsize, &phy_addr, GFP_KERNEL);
The dma_alloc_coherent() function fails when trying to allocate a 25MB memory space.
The issue would not happen on MPSoC platform.
It is caused by the memory size limitation controlled by CONFIG_FORCE_MAX_ZONEORDER.
It is set to 11 in Zynq-7000 and set to 19 in MPSoC.
So for Zynq-7000 the maximum size is 4MB.
After modifing the value from 11 to a larger value(like 15 in my case) the issue would not occur.
You can find the kernel configuration entrance here:
petalinux-config -c kernel
kernel features -> Maximum zone order
Best Regards,
Jason
Re: ERROR: "[DNNDK] Failure of DPU memory space used out" when trying to run DNNDK on Zynq-7000 platform
Thanks to @gguasti here comes an AR about step to step flow to implement DPU on Zedboard design:
https://www.xilinx.com/support/answers/73058.html
Best Regards,
Jason
Best Regards,
Jason
