Visitor tacbook
How to define calibration.txt for ssd
Dear all,
I am now trying to quantize my ssd model, but I don't know how to define calibration.txt for ssd.
( Generally ssd seems to need not only class number but also coordinates in image..)
Does anyone know how to do it ??
Visitor tacbook
Re: How to define calibration.txt for ssd
Dear Ivalena,
Thank you sooo much for telling me in detail!!
As a result, I tried to deploy my ssd model step by step following by the tutorial you told me, and finally I successed to inference correctly on ZCU104!
My biggest mistake was the wrong number of "num_class"...
Again thank you very much for your great advice!
Best regards
Please see the ML-SSD-PASCAL-Caffe-Tutorial.
Click on float.prototxt to see where calibration.txt is located.
The path is relative to the DNNDK_Project directory
Follow the trail, and you'll find the calibration.txt file used in the tutorial.
Good luck!
Louie
Visitor tacbook
Dear Ivalena,
Thank u very much for replying me!!
In my recognition, decent tool needs calibration data to re-train model while quantizing(in order to keep accuracy), doesn't it?
So in case of SSD, it seems that we need to define not only class number but also object coordinate in calibration.txt.
But in the tutorial you told me, there are only class numbers of each image.
Is it enough to quantize by dnndk??
Best regards.
Quantization does not involve retraining (i.e., backpropagation). The generic process for quantization is described in this paper: Fixed Point Quantization of Deep Convolutional Networks. The general steps involve:
  • Runing several forward passes in floating point using the calibration dataset and recording the activation results
  • Creating a histogram of the weights and activations for each layer
  • Determining the maximum and minimum values from the histograms and selecting an appropriate mapping to fixed-point.
Thus, the calibration dataset needs to be "representative" of the actual data the neural network will encounter during deployment. For example, if the training dataset includes well-lit as well as poorly-lit images, but the calibration dataset only has well-lit images, then the resulting quantized model will be biased toward well-lit images and perform poorly when provided with dark images.
The format of the text file is defined by the ImageData layer.
Visitor tacbook
Dear Ivalena,
Best regards
Visitor zzc
how to define the number of num_class?
