Observer adu0956
ML suite newbie question
I am trying to get ML suite running. Following are the steps I followed  Trying to make it work on my linux System:
    a)Git clonned ML suite repository to my local machine ,
     b)installed  Anaconda and went through set up , it did get   completed with no erros. using this link :  https://github.com/Xilinx/ml-suite/blob/master/docs/tutorials/anaconda.md
    c)installed  lfs using https://github.com/git-lfs/git-lfs/wiki/Installation went through successfully
    d)tried to pull the ml models using lfs in the ml suit directory, it failed. Would this affect       further follow up with the tutorials??
Do I need Amazon AWS EC2 F1 ML suite instance to run all the tutorials ?? Can I run it on normal Linux machine or an just Amazon Amazon AWS EC2 F1 instance? Currently I am confused between Amazon AWS EC2 F1 instance and Amazon F1 instance ML suite .
Re: ML suite newbie question
We are running into some model delivery issues right now. I will directly send you the models via email. Thanks, Kamran
/k
/k
Hey,
To run inference on an FPGA you need to have a system with an FPGA card plugged in. Amazon AWS EC2 F1 is a cloud system that can provide this setup to you. Nimbix is the other. You can also buy FPGA cards from Xilinx to test these features out.
The compiler and quantizer can be evaluated on any linux system, because its just python byte code.
Thats actually not a bad idea, because it can help you determine if your model is ready to be ran on the FPGA.
Observer adu0956
I was able to run the inference on the AWS. The problem was the GitHub lfs system which Xilinx has provided has been broken. Thus I requested for the tar files for the models and I was able to run the inference.
Participant mkaiser
Same issues with the model download here. Can you send me the models per mail, too?
Martin
