Xilinx AI SDK v2.0.5 issue with UG1354 Setting up ZCU104
I am trying to run the included demos from the AI SDK from the AI developer hub (https://www.xilinx.com/products/design-tools/ai-inference/ai-developer-hub.html#edge) using the instructions starting in Chapter 2 (page 12) of the UG1354 document.  I am able to successfully set up my host machine without any errors, however when I go to the "Setting up the Target" section (page 16) I fail.
Question 1:
I have downloaded the board image (xilinx-zcu104-prod-dpu1.4-desktop-buster-2019-04-23.img.zip) from the AI developer hub - is this the right image to use for the AI SDK and the ZCU104?  I used it since it was referenced in this post as working: https://forums.xilinx.com/t5/Machine-Learning/Customize-DPU-IP-and-run-Xilinx-AI-SDK-examples-on-Xilinx/td-p/979083
Question 2:
In step 2, installing the AI Model Package I am successful in scp the xilinx_ai_model_ZCU104_2019.1-r1.deb file to the / directory of my board.  However, when I run the "dpkg -i xilinx_ai_model_ZCU102_2019.1-r1.deb" command I get an error:
Error: System required version 4.19.0-xilinx-v2019.1
My best guess is that the issue stems from using the incorrect board image but I'm not sure which is the correct.  Any help would be greatly appreciated!
Re: Xilinx AI SDK v2.0.5 issue with UG1354 Setting up ZCU104
So, the answer to both question 1 and 2 is to use a different board file other than the one I mentioned in the linked related forum post.
After using the image file: petalinux-user-image-zcu104-zynqmp-sd-20190802.img.gz I was able to finish the installation of the AI SDK onto my ZCU104.
