Visitor shixiaoke
resnet50 sample can not work
I want to run the resnet50 model(tensorflow version) on Ultra96v2. But when I run the resnet50, it can not work.
The board displays this message:"[DNNDK] Invalid Node name fc1000 specified for DPU kernel resnet50_0."
I do not know where go wrong.
Any help would be greatly appreciated.
Re: resnet50 sample can not work
hello
you could find some help here https://www.xilinx.com/support/answers/72804.html
the Answer record is based on ZCU102, but you could get some hints from included main.cc, input function and make file.
Hi @shixiaoke ,
It seems that you specify a wrong output node name.
I can get similar error when I try to modify the src/main.cc and set a wrong "OUTPUT_NODE" name.
Where did you get the DPU kernel ELF file?
After quantization there should be a xxx_kernel.info file, you should find the right Output Node name there.
Hope this can help.
Best Regards,
Jason
hello
