7 series DDR3 MIG simulation, how to speed up?
Hello everybody:
I use Modelsim SE to simulate 7 series MIG core generated by ISE 14.6 coregen.
The parameter setting is as follow:
parameter SIM_BYPASS_INIT_CAL = "FAST";
// # = "SIM_INIT_CAL_FULL" - Complete
// memory init &
// calibration sequence
// # = "SKIP" - Not supported
// # = "FAST" - Complete memory init & use
// abbreviated calib sequence
I run under "FAST" mode, but it still takes 8 minutes for calibration to be done, and I tried "SKIP" but errors happened and simulation stopped.
I tried setting ps as simulation resolution instead of fs and comment out  "log -r /*" in sim.do file, but it seems no change on simulation time.
Could anyone help me with this? Thanks!
Yes, Slow simulation is main draw back in MIG 7 series IP, but based on the feed bcak the simulation time is greatly improved for Ultrascale.
Unfortunately you have to bear with the slowness , FAST is the only option.
MIG 7 series do not support SKIp option for simulation , you can check this in UG586 as well
You should see calib_done asserted around 50us of simulation time real time depends on many factors like machine RAM, Simulator used.
Also you are not supposed to change the simulation resolution time other than the one given in sim_tb_top, if you did calibration may not complete and possibility to see errors
If your version of MIG UG shows SKIP is suported then it is incorrect
Please refe below link which applis to DDR2 and 3 as well.
http://www.xilinx.com/support/answers/57437.html
To speed up simulation only FAST is the option.
Other factors like memory width can effect the simulation time.
Please use Questasim for better results
Moving to MIG board.
Debraj
Yes, what I could choose is only "FAST" in my MIG simulation.
I installed Questasim but it is not any faster than modelsim.
I use optimization option in vsim command: -voptargs="+acc+sim_tb_top", then I get three times faster.
By the way, I test Modelsim 10.1a, 10.2c, and QuestaSim 10.2c, it seems like QuestaSim is not faster than the other two.
