Artix 7 Resource Estimates for DDR3 controller
I am trying to find a document that provides an estimate of the resources required to implement a DDR3 controller in an Artix 7 device.
Hi @pgigliotti_usac
Please have a look at Table 1 in the MIS Datasheet for resource utilization and you can then compare them across different devices using the Artix-7 Datasheet
Hope this helps.
Hi @pgigliotti_usac
OOC output products provides, Generate IP output products.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
I am sorry, are you telling me that I need to generate the IP to get an estimate.  Is it not in a document somewhere.
Hi @pgigliotti_usac
Hope this helps.
